1.6 L OMC only running on 3 cylinders
Trucker G
I have a 1983 OMC 1.6 L it's not firing on the top right cylinder has 95 pound compression it's getting fuel it's getting spark what am I missing
oldboat1
The Sea Drives were 2-strokers. What's the history of the motor and maintenance? Been stored?
[edit. 50:1 if premix. 100:1 was tried and abandoned in the '80s, so might be relevant.]
Trucker G
When I bought the boat it had a blown head gasket on the right side replace the head gasket clean carburetors new plugs fired right up seems to be running okay at home that felt like it was a little sluggish on the water pull the plugs out and they all look fine except for one which still look brand new
oldboat1
If only one is like new, suspect water intrusion in that cylinder. Repurpose a timing gun, and check each lead while running -- no flash, no spark.
For water, could be head cover warping or an uneven torque issue.
Clean sparkplug caused by ----No ignition -----No fuel -----No crankcase compression.---No cylinder compression take your pick.
Trucker G
I replaced both head gaskets! Compression 95 to 100 lbs on all cylinders it's getting spark and fuel! How can I check crankcase comp.
Faztbullet
How do you know its getting fuel??? Take a squirt bottle of fuel mix and spray in carb throat,if pics up its carb. Was the cylinder scuffed??
Tim Frank
How do you know it is getting spark to the bad cylinder? What was your test method?
Trucker G
Already tried the squirt bottle! As for spark I pulled the plug out stuck it in The Wire and cranked it over nice bright Spark
Tim Frank
What I thought.... :)
That tells you only that when you remove the plug and lean it against the block that the spark jumps about a 1/32" gap.
You need to make sure that it will jump a 3/8" gap in an open-air spark tester.
Trucker G
I found my timing light and every wire shows it's sparking except for that one cylinder???
Trucker G
Just want to say thank you to everybody that tried to help with my situation
