ScottsdaleArizona
Thread starter- Joined
- Nov 6, 2019
- 6
I recently bought and nice old Glaspar with a 1964 Johnson 90 HP outboard… it starts right up and idles good until the water pump kicks in… At which point water starts dripping out of cylinder 4 where the spark plug is plugged in ..causing a rougher idle… I pulled the head off and noticed quite a bit of build up under the water jacket cover when I pulled off the gasket .. the other side looked clean as a whistle .. pistons didn’t look they’d seen any water at all either.. I cleaned all the surfaces extremely well.. installed a brand new head gasket and also installed a new water jacket gasket using permatex 2 non drying form a gasket sealer .. and it’s still leaking water out of the hole where the plug goes into cylinder 4.... I’m a novice at boat repairs.. but my reading leads me to believe maybe the water jacket cover is slightly warped from a previous overheat ? Also one of the 17 bolts that hold down the jacket cover is somewhat stripped.. it won’t totally bite down...eBay has a bunch of used port cylinder head assembly’s ... would A new one fix it? Any help would be much appreciated .. I’d really like to take her on her maiden voyage! I’m thinking I probably shouldn’t until this is resolved ... thx!
