papayadialog
Thread starter- Joined
- Jul 11, 2018
- 9
I bought a 99 Aquasport with an Evinrude Ocean Pro 200 a year or so back. Engine wasn't running, so I went through everything. Ended up with new CDI, pick up, stator, and a carb cleaning. Has been running well since. Low oil light came on last trip on the way back to the dock but no alarm or anything. Went to start it a week later and it was a bit difficult to start, but it ran on the hose for 10 minutes after firing up and then stalled. Was very hard to restart after and wouldn't run without pushing the key in and activating that start solenoid mechanism. I assume the fuel pump is acting wonky. It was leaking fuel when I bought the boat and I had to reseal it. So I was thinking just replace it so I don't get caught on the water with it acting up.
To me the vro seems needlessly complicated and I wouldn't mind just premixing. At least I'd know that the engine is lubricated.
Anyways, this post isn't about the viability of premixing vs the factory designed oiling pump. I just want to know if there is a preferred fuel pump for these larger ocean pro engines for premixing. I was planning on purchasing this one:
https://www.michiganmotorz.com/johnson-evinrude-injection-conversion-fuel-pump-p-11494.html
Any advice on choosing a pump would be greatly appreciated.
