massimofinance
Thread starter- Joined
- Oct 30, 2004
- 508
Stick with aluminium, and consider it a Sacrificial Lamb. With a SS if the prop doesn’t bend, the Driveshaft certainly will
.... Would have aluminum props saved them, probably not
Thanks guys. While I consider SS and Alum., should I be worried I caused internal damage at all? Anyway to check that. Also, I’ve been having issue getting on plane, should I consider a 4-fin prop?
A few weeks ago I was cruising at 19 and something suddenly popped and it started going at 26knots.
Couldn’t replicate that again unfortunately.
Ayuh,..... I suggest you fix yer motor, before worrin' about the prop,......
Nah, that'll buff out...
If you can afford it, go Merc genuine stainless steel...
(Cue the 'stainless steel will damage your gears' peanut gallery)
No it will not! A stainless steel propeller is better for holding its shape, has thinner blades for better efficiency, and is less prone to destructive damage, like in your photo... You can bend a blade and it can easily be straightened out.
I have no idea where this stupid theory about gear damage came from, but after running my own boat shop for years and continuing to maintain friends and relatives boats, I can say there is absolutely no evidence to support it... I have seen shafts sheared, gears chipped and crack with both Ali and SS props. I've also seen a SS Prop with 2 blade folded hard against the hub with the drive line completely untouched. The extent of gear and shaft damage has no correlation with the material the propeller is made of!
The only 'advantage' of an aluminium prop is that it's cheaper...
Chris....
First impact(rocks) I had with the SS on my VP(10 hrs on it) bent and tore the blades of the prop and bent the Shaft. The prop was a Raker which had a Rubber Hub
