Will.drift
Thread starter- Joined
- Aug 25, 2019
- 6
This may be a little bit of a odd question but hope I can find the answers I am looking for. I have a 1994 Glastron ssv195 which was originally equipped with a 4.3 4bbl mercruiser and what I assume was 1.84 gearing? The boat came without a leg and motor so now I have swapped in a 220hp 2bbl 5.0 and a 1.5 gear ratio alpha one gen 2 outdrive . With a 21 pitch aluminum prop I can hit 37 mph wot with a normal load of people and fuel tank. However I can over rev it if I want and it will still pull harder. This is where it got a bit strange I put a 23 pitch prop on and the boat would barely rev above 3000 rpm and not accelerate... and on a prop slip calculator it’s showing something crazy like 30% is jumping to 1.47 gears from the proper 1.65 going to make all the difference I feel the boat should be Seeing closer to 50mph with a decent cruise speed . Any help/ suggestions would be much appreciated thank you.
