So I’m changing gaskets on my 4.3 mer cruiser and I can not for the life of me get the intake manifold and cylinder heads off the block. All bolts removed soaked with PB Blaster, no luck. Any tips or tricks from experience out there?
what is the reason you are needing to change the gaskets. most of the time if you have water in the oil, its a crack in the block from lack of winterization, or the exhaust manifolds failed and allowed water in the cylinders.
if you have water in only one cylinder, 99.99% of the time its your exhaust manifold to elbow joint has failed.
however since you have the bolts already yanked..... you now have to do a complete tear down, clean up of all surfaces prior to bolting it back together.
