TyMac17
Thread starter- Joined
- Aug 21, 2019
- 5
Hello All!
I am very new to boating and was given an old 12ft aluminium, with a 1965 Evinrude 9.5 Sportwin from my landlord. This is my first boat, and although I grew up working on dirt bikes, cars, atv's, etc. I am not familiar with outboards AT ALL. The motor hasn't been started in over 6 years, and after cleaning and rebuilding the carburetor, new spark plugs and points set to 20 thou, I am unable to get the motor running. After this I took a deeper look into everything and pulled the head off, to find that the lower cylinder was filling up very quickly with fuel. Luckily I found the reeds to be stuck open which I believe is what was causing the cylinder to fill as after pulling the reeds, cleaning them and checking for proper operation, the cylinder was no longer filling up. It is getting great spark and proper fuel flow. However, I am missing the linkage for the low speed mixture knob, and not entirely sure what it should be set at for start up (I set it roughly 1 1/2 turns out). I did get it to turn over and run for about 4-5 seconds on a few occasions, however it cut out right afterwards. I am just wondering if there is anyone more knowledgeable about these motors than I am that could help me out, and point me in the right direction on where to start.
Thank You!
Thank You!
