swimmin' for shore
Thread starter- Joined
- Oct 25, 2004
- 490
Restoring these older boats, it's cost-prohibitive to go with some of the expensive models I've seen on the net, but I want to do this. It'll be a fairly shallow cooler, as the bench has to be fairly low...14' 1978 Fiberform...<br /><br /> Does anyone know of a good place to find gasket for the lid/cushion to set down against and seal the cooler? It'll be in the back, so I figured to build a pretty basic box, a plug on the bottom so that it can be drained into the bilge, fiberglass it inside and out, and then paint. I want to put a gasket around the top, and a latch to lock it down onto the gasket with. Simple enough design. Now with the questions:<br />1. Where can I get gasket? <br />2. Will it be fairly simple to glass this over, or am I going to have problems with the glass wanting to pull back at the edges? I could staple it until the resin dries enough for the glass to be stiff...<br />As always, all suggestions on design, materials, workmanship, etc... are welcome. You guys have saved me from myself once or twice.
