jimmbo
- May 24, 2004
- 14,672
I don't know about the timing advancing.
I believe I have a small hook bottom.
The stringers transom and foam were waterlogged. some areas were bad and some were ok.
The cam was bought on ebay and I compared the two camshafts. Plus it had the cam lobe for the mechanical fuel rod.
A hook can knock several MPH off the top speed, and it doesn't need to very large at all.
Did you remove all the soaked foam?
New or Used Cam? VP, Mercrusier part #s
How did you compare them? Even my my Micrometer Eyes have trouble measuring Duration and Lift. 1990, that would be Pre Vortec.
