Help selecting a used 24-26' Lake Cruiser
rtpguy
Quick background - new-ish boater, it's been in the family and friends to the point of loading/unloading and piloting a friend's pontoon pretty often, renting pontoons and Sea Doos, but not owning and never piloted a small Cuddy-sized cruiser. I've worked on my own vehicles and motorcycles since I was a kid, including some extension modifications making a couple of cars track-worthy. Time is sometimes short, so I'd expect I'd be doing most but not all work on the boat.
In part due to time, we'd have the boat at a marina in a slip of a large freshwater lake. No expectation to bring a cuddy/pocket cruiser to the ocean.
Usage: Mostly my wife and I, + 1 couple on occasion. Has a much better chance of success if it's 'wife-comfy,' which considering the summer humidity here = shower, toilet w/tank are strong bonuses. She's completely into the *idea* of heading there Friday night after work, sleeping onboard, then going out for the day to play on the lake, so considering the summer humidity here, having shore AC/heat would be a winner, although not entirely opposed to adding if it's feasible. Being able to stand or not crouch too much in the cabin (I'm 6'0, wife's 5'7") would be a bonus as well.
In general, most usage would be lake cruising or camping at the pier or one of the lake 'beaches' but sleeping on the boat. Pulling a tube, but not likely to be skiing or wakeboarding.
Have read and researched until my eyes are ready to bleed. I started out with 'get the smallest boat that meets the need,' considering relative $ and in the event we sell in a few years (if we use it less than expected), but then have been climbing upwards, probably unsurprisingly to most of you, based on trying to get some of the options for our use.
Budget is $15-$25K, used obviously, will pay in cash. I *could* go higher, but generally just don't want to as it's a luxury purchase and one I need to see us using regularly in reality before wanting to go higher (in the future). I'm open to waiting until winter if I need to in order to find the right deal.
Right now am considering along the lines of the following after reading up on brands, models, and also looking at layouts - I like the searay/chap/crownline port-side lounge opposite the pilot's chair, so don't think I was able to find a Montery model with that layout, and some boats I'm ignoring based on collective wisdom/comments of lower quality.
Crownline 250CR or 260CR
Chapparal 240 or 260 Signature
SeaRay 24-26 Sundancer
Rinker 250 Fiesta Vee
Four Winns 248 Vista, 242EC or similar
Some of the models may have similar other models I'm unaware of, but also considering e.g. Crownline 260 CR, while of course budget moves the needle to different years based on the boat in those ranges, but generally I'm seeing options in the 1998-early 2000s range. As has been repeated on the forum, upkeep at this age of boat may indeed be more important than brand, but am also looking for the feature set and layout that fits us. I also do not want to go larger as I'll be learning to pilot it vs 22-26' pontoons at the same time as well as budgetary reasons.
I have a very low idea on what specifically to look for or look out for at this point. Compression/leakdown check, look for soft spots anywhere, etc. and will likely have a survey done, although I have no idea how much to expect to pay for one…can usually tell if a boat's been run in salt water by the outboard itself. I have come across a few interesting boats with seemingly low hours, i.e. a 2002 Chap Signature with <300 hours, but I don't know (yet) the main service intervals for I/Os other than it seems impellers should be changed often(have done this on outboards, not I/Os before). (Any suggestions for a good maintenance book covering this range of pocket cruisers would be very welcome).
The lake doesn't freeze, so the assumption is the boat would mainly live in the slip, other than having to pull it for required maintenance, which as mentioned I'm trying to get a handle on. Seems like outboard service (gear oil), hull cleaning and wax are the main times the boat needs to come out of the water, while I'm expecting in advance to be replacing cockpit covers as needed, and doing most of the 'inside the boat' maintenance myself.
Engine-wise, have seen the comments on 5.0 being somewhat underpowered, while it seems the 5.7 or even the 7.1 don't have significantly worse fuel consumption unless WOT. I'm not under the illusion of this being a speedboat, but I expect to at least get up to 35MPH or so, higher being better but not a significant buying factor. No experience as to why, but going to take the wisdom of dual props being more maneuverable so that's on the bonus list.
I have no clear idea on the differences between Volvo and Mercruiser. I understand for the most part Mercruisers are Chevy engines, sometimes modified, with marine-ized electric and fuel systems. Considering the boat will mostly be in a freshwater slip, I don't know if one is beneficial over the other in any way, outside of the inevitable brand loyalties?
I'm widening my search range and am *considering* if I'm willing to buy remotely (with a survey and much discussion). Unsure if this is a 'good' idea or not, but am considering it if the right deal comes along. Has anyone paid to have a boat transported for them, with a trailer part of the sale or not, and have any ideas on costs, and thoughts in general?
Long rambling post, but if anyone has any thoughts on models, years, engines to consider or to avoid, things to look for/look out for/consider, or a pointer to getting better equipped on the maintenance side of things, all comments welcome, as I'm about in analysis paralysis so need some external thoughts before I just go ahead here and work it out as I go. :)
Thanks in advance!
roffey
I think you will find everyone here will say its all about condition and what fits you best. Price and year are not always first and second on the list.
Lowlysubaruguy
I looked at a lot of boats in the 24 to 28 foot range until I bought two years ago. There may be some negative views on this boat but I drove to see two of them even made an offer on one, in the price range and size your looking at it is a fit. The bayliner 265 I found a couple with less than 100 hours on them in like new condition close to your price bracket. I wanted more of an ocean boat which was never going to happen with what I wanted for options I tossed a really low cash offer on one of them thinking I could use it for a couple years and search for the right boat he turned me down and I had to step up my price range a fare bit. But this series bayliner had a lot of cowbells for the money.
One boat in your size range that has a great ride is a 26 foot Larson good on fuel the one I spent a lot of time on saw some abuse and had few issues, but a later model one will be out of your price range. But the bayliner has more cabin space.
dingbat
My suggestion would be to buy a small runabout and see if you actually use it.
I’ve seen it all to many times. All sounds good until you find out how much money, time and effort goes into owning a boat. The term “Break out another thousand” is reality.
Maintenance wise, the items you mentioned are just the tip of the iceberg. Unless you have a lift, you have bottom paint to deal with as well. Then you have off season storage, in-season repairs that require the boat be pulled, in-season upkeep, etc.
Poor workmanship and inferior materials don't improve with condition. ;)
Blind Date
Agree. Condition is a given. Buy a cruiser with quality deck hatches/port windows and hardware that is mounted with nuts & bolts, not screws. Cabinetry molded out of fiberglass versus wood panels wrapped in vinyl and screwed together.
Put Regal on your list. They are good about putting plenty of ventilation in their cruisers, have great layouts & top notch build quality.
My must haves when I was looking for a 24-26' trailerable cruiser 15 years ago. These may or mat not be important to you.
No 5.0 engines or Alpha drives.
No porta potties .
Camper Canvas
Port windows that open w/screens.
Easy bow access
Vinyl headliner
My biggest gripe about my 1997 250 Sundancer is the head is too small. But tough to find another boat in that size that comes standard with a vacuflush head or even offers as an option. Also the carpeted floor in the cabin is a terrible design. Look for boats that have vinyl cushions and fiberglass lined floors. The less fabric down below that can absorb moisture and mold/mildew the better!
Good luck in your search.....the hunt is the always the best part about buying anything IMHO!
tpenfield
Many of the 26 foot cruisers have a single engine, but you are right on the cusp of needing twin engines.
I would add the Formula 27 PC to that list. You might find one for $25K that is in decent shape.
If you go with a single engine boat, make sure it is the 7.4 (454) or the 8.1 (496) and not a 5.7 . . .
Of the brands listed earlier in this thread, I would favor the Sea Ray and the Chaparral over the others.
ryds-steve
Hi, just curious why Maxum has not been mentioned?
i’m in The UK and am in the process of finding a nice 2400 or 2700, anything I need to know?
Sorry if i’m Hijacking this thread.
ryds-steve
Ok, Maybe I should have said I think the OP should add the Maxum 2700 SCR to his list of potential boats.
rtpguy
Update - I did read the various replies but work has been quite busy.
Many boat ads and visits later, we closed on our boat, which initially was looking most likely to be a Sundancer 260 or 260 Signature, until we spent some time on one, followed by a 270 Sundancer.
The 270 won out - wider 9'2" beam, 7.4L MPI new engine with 88 hours on it, 600 hours total on boat, separate dinette, HVAC(a must for the SE US), no generator.
It's in process of getting a new (rebuilt) lower and HVAC replacement (which was known, expected, and factored into the pricing). A prior interested party had a ($800!!) survey done, which I subsequently bought from him for $100. He wound up going much newer and much more $ as he wanted to be on the water for the remaining season, while I pretty much knew we were going to be heading into dry storage, so I had time to deal with what needed dealing with.
I'm mixed overall on the prior owner/boat history, but with pros and cons.
PO had a lot of $ into the boat, but it also seemed he'd wait for a problem to happen before addressing, which then became big $ (engine replaced). New canvas including cockpit cover and bimini but no camper. Hull had a fairly $ cleanup/polish job done on it, new bottom paint, new steering cable, tuneup, fair amount of maintenance records and repair history. Interior is immaculate, and in 'normal' non-80s'porn-movie fabric - cream vinyl vs the insane fabric patterns.
Almost had to bail on the deal due to lack of trailer with the boat, but came through with a tri-axle aluminum Loadmaster for $2k, versus ~$7K on up for a new trailer. Considering the boat will be slipped and dry storage at the marina off-season, it just wasn't making sense for a 2020 $ trailer to use it a small handful of times yearly.
Will see how it goes. The biggest $ items are effectively new or near new with the lower, engine, HVAC and various pumps being replaced, wife's happy about it, and I'm happy with it and the overall $ invested, in that even if/when the 'unexpected' parts or repairs are needed I've got cash on hand ready for it, while we can break even fairly easily on it as we did some heavy downward negotiations allowing for the repairs, etc.
Now, if only it would hurry up and warm up already! :)
roffey
LOL, I did that about 6 years back, bought a boat at the end of the year then had to wait till spring... long, long winter. Congratulations on your purchase. you will enjoy for sure.
Texasmark
You said SE, assume US. Why wait? I couldn't on a boat I bought in the fall and as soon as I could get my arms around everything needed, out we went.
rtpguy
Thanks. Was hoping to have her in the water this weekend, but waiting on shop to finish up as well as deliver it to my local marina to it’s waiting slip. New lower is in, new 10K HVAC is in, boat has been dewinterized, fingers crossed for next weekend or the following.
I’ve got a new canvas set coming my way - went back and forth on this a bunch, but just not as fan of the teal, and for the price of adding the visor, sides, aft camper and sides, I’m at around the same price, or close enough, to just swap to heather/tan from the teal on the boat’s Bimini and camper top.
It’s frustrating waiting on the shop to wrap up at the moment, but I need them to do the delivery while I pick up an appropriate vehicle during the season...also a bit frustrating in that I normally do nearly all of my own work on vehicles, motorcycles, house and expect this to be the case with the boat as well, but also figure it’s well worth the relatively few extra $$$ to get the niggling things done now with a bit of peace of mind so we can be relatively ‘get on the water and enjoy.’
I’d had a heck of a time getting in touch with apparently the SINGLE person at the marina that knew what they were talking about - had been #4 on the list since October or so, but seems like only the owner (vs a half dozen others) had any real idea what was going on there, and couldn’t reach him. Luck shone on us for once, and finally managed to get a hold of him, and have the slip sorted, waiting for the boat.
Considering the whole COVID situation now...I already worked from home office quite a bit, but now my wife (teacher) is doing so as well, there may well be some ‘work from boat’ time coming up occasionally. I’m usually in so many meetings daily it won’t negatively affect anything, while at least giving me a change of scenery now and then...and sorting a combo TV/second laptop display for the boat. :)
So overall a bit delayed on getting her in the water, but fingers crossed, soon.
rtpguy
Not much selection in the local area, so went a few hours away for most of the boat shopping. Adding to that I have the slip (now) but not yet the tow vehicle, it was always the plan to have some work done through the winter and then delivery to my local slip.
tpenfield
Congrats on the 'new' boat . . . I hope all goes well. A friend of mine had the same boat except it had a carburated 7.4L instead of the MPI. . . . Seemed like a nice boat.
It always seems to take longer to get boats ready for the season.
