bruisedreed
Thread starter- Joined
- Jul 8, 2019
- 19
So really haven't been able to get anywhere with this issue. Started with a motor that was pumping water, just not as much as I thought it should. Replaced the impeller and had NO flow after. I have been slowly acquiring all the parts I can think of that have anything to do with the cooling of the engine but I just can't make it work. I put the old impeller back in the pump, nothing. I can't figure why I cant get the pump to gulp manually with the lower unit submerged. The parts diagram shows the gasket around the driveshaft (0309607) and a washer seal (0309583) above it. The gasket was in the water pump when I initially took it out but there was no washer. My question is that gasket does NOT fit tight to the shaft. I can't really figure what it does other than create a little dampener or skirt inside of the shaft passage through the pump. SEE ATTACHED PIC...this illustrates what I'm seeing (notice the gap between shaft and seal. Is it possible this isn't the right seal? I'm not sure that is any issue, but I can't see anything else that wouldn't make this pump. there aren't any other parts to it really. Impeller is turning, key is in the shaft water passages are clear. I'm really stumped.
