kmilley
Thread starter- Joined
- Apr 17, 2017
- 6
Hey there everyone, hopefully, I can get some guidance on what to do with my motor as I can not figure out for the life of me why the thing is not pumping water... I'm fairly new here so if anything is wrong feel free to let me know. I picked this motor up for a good deal but can't seem to get it to pump lots of water.
Model number - 40E75C
Serial - C27387
1) took the lower unit apart and changed the impeller, noticed grommet that feeds the water up to the engine was messed up so replaced that and put it all back together, still not pumping water.
2) took the lower unit off again and inspected further by blowing air through the water system, air travels through perfectly but noticed the grommet below the powerhead was messed up a little so had the powerhead removed to change that grommet. still not pumping water.
3) tested the lower unit in water with a drill on the driveshaft to see if it was pumping water properly and everything was working perfectly. So removed the thermostat to see if water was making it all the way up and it was but not nearly enough water.
4) removed the head gasket to see if it was maybe leaking? (engine starts and idles perfectly) replaced the head gasket but did not pump water.
5) changed the impeller housing and even tried a different lower unit to see if the problem persisted... when the motor first started it was not pumping water for about 15 seconds but then started spewing water like it should for about a minute but then stopped.
Pretty well ready to give up on the motor at this point... other notable things include that the copper pipe where the water flows up has a hole in it (was told it cools the exhaust and it should still pump plenty of water upwards). The motor does pump was but VERY VERY little, not enough to cool it at all. The motor goes into fwd, rev and neutral all perfectly, but does not pump water...everything is lined up properly and the water is high enough on the motor for sure.
Any help would be greatly appreciated, as I am at a loss for words on this thing.
Serial - C27387
