Interruptor switch
Roach12
Is your shift interruptor switch suppose to activate on land or only when in the water when it has a load on it?
Bt Doctur
  • only when in the water when it has a load on it?
    Tags: None
    • Quote
    • Flag
    • Like 0
Bt Doctur
Do you have a shift control cable behind the control box or just wires? You may have a type of electric activated shift system.
Post a pic of it
harringtondav
The shift interrupt switch - cutout switch - only opens when you shift out of gear with the propeller in water. It may twitch a bit when you're shifting out of gear on muffs, but it's unnoticeable.
tank1949
The slight delay will be much more noticed (hopefully) in the water under load. If your tack's RPMs don't drop for an instant and climb back, you have bad switch OR linkage is worn and not within needed specs. Trust me!
