Priming fuel system
nola mike
Doesn't sound like you're having much luck. Guess I'd start with the ignition. What do you have on there now? If you're flooding, that might be the case of your no spark. Do you have spark from the coil? As for fuel, is the needle seating? You can blow in there with the float raised and see. If so, might need to check your fuel pressure next.
studders
The type of ignition is a distributor based. I haven’t checked the spark from the coil as of yet. I’ll check that when I get back under there hopefully this afternoon. What do you blow in to see if the needle is seating?
