Iskander-M
Thread starter- Joined
- Jun 19, 2019
- 28
Hi guys,
Can please anyone tell me if the M10 would suffice to fit the BF150? The Honda fitting instructions suggest 4x M12 bolts but I need to use the 10mm. The reason is the that the engine sits on a stainless Gil Marine bracket which creates an electrolysis and I had some corrosion issues.
The idea now is to fit the engine with an acrylic shield 1-2mm between the bracket and the engine and use the M10 bolts with shoulder washers so there is absolutely no contact between stainless bracket and aluminium engine parts. That will be the 12mm finished diameter to fit in the engine’s holes.
Checking the stainless bolts shear resistance I find that a 10mm bolt A2 70 would hold a 1.8 tonnes so 4 of them totalising 7.2 tons so looks not bad for a 225kg engine.
Any suggestions or opinions? Thanks in advance.
