why is trolling hard on the splines an coupler ?
aerobat
Master Chief Petty Officer
we live inlands with speed limited channels . we troll all days long at 1500 rpm often . ( 5.0 mpi b3 )
i heard its hard on the splines and the coupler but why ?
revs are low , the force is low comparing to being on glide . is there a technical explanation for this ?
best regards
achris
More fish than mountain goat
Because it's not holding the spine and coupler in the 'loaded' position... The boat is not on the plane, so the load is on and off. The coupler and splines get a flogging...
Pull the drive twice yearly and check the splines, make sure it's greased properly.
Chris...
aerobat
thanks ! i also grease the splines via the nipples on the coupler
scoflaw
Ensign
Here's my take on Mercs reference to idling. Neutral out of gear, that's no load. 1500 rpm in gear, there's plenty of load n solid push
aerobat
thanx scoflaw ! of course i do not idle the engine at 600 rpm in or out of gear all day long , that would be nonsense !
so 'cruising' at 1500 is a non issue beyond normal maintanance and greasing i guess and hope !
metsfan3197843
Unless you live in Alaska and slow troll for salmon all day....not much of a way to avoid that up here if you want to stay dry and warm while trolling
Rick Stephens
In the end, when I did the math, it was cheaper to add a kicker to troll with. Long term maintenance costs, and fuel, made mounting a $1000 used outboard a better option for me.
metsfan3197843
did you add forward controls and steering? Every time I think how nice that would be I see the cost!!!
