Dbobjack
Would sudden spike on stator ohm test indicate problem,this is on 77 Johnson 70 hp ohms went from approx 650 to 1050 with stator unhooked from pp dva is around 350 when hooked to pp dva is unreadable, flashing. I was going to put new pp on but stator scared me away,,,any ideas
gm280
Could you explain the ohms reading a little bit more. How do you know it went up? Did you read it some time ago and then reread it recently to see that difference, or did it jump up in resistance while checking it? :noidea:
Joe Reeves
With the stator wires disconnected, if the ohm reading suddenly jumped 400 ohms when taking a reading, that is normally due to having a poor connection then suddenly corrected.
However, look at the stator closely to see if possibly there is a sticky looking substance dripping from it down onto the timer base and the powerhead area. if this dripping exists, replace the stator regardless of what reading you get from it. The dripping would indicate that the stator has overheated... in which case, especially if your tachometer us acting up or quit altogether,,check the rectifier as follows.......
(Small Rectifier Description & Location)
(J. Reeves)
On most 2,3,4,6 cylinder engines, the small rectifier is located on the starboard (right) side of the engine just in front of the engines electrical wiring strip. There are a few older V4 engines that have the wiring strip on the rear portion of the engine and the rectifier would be located just under that terminal strip. The smaller horsepower engines usually have the rectifier located on the starboard side of the powerhead close to the carburetor area.
The rectifier appears to be a round object approximately one inch (1") in diameter and also about one inch (1") high. The base of it is sort of triangular in appearance and is attached to the engine with two (2) screws/bolts..... usually one screw/bolt is larger than the other. The rectifier, depending on which one your engine uses, will have either:
One Red wire, one Yellow wire, and one Yellow/Gray wire, or One Red wire, and two Yellow wires.
Note that either of the above rectifiers could have a fourth wire which would be Yellow/Blue
(Small Rectifier Test)
(J. Reeves)
Remove the rectifier wires from the terminal block. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray, then the red wire (some rectifiers may also have a fourth yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction.
Now, connect the black lead of the ohm meter to the red wire. One by one, connect the red lead of the ohm meter to the yellow, yellow/gray, and if present, the yellow/blue wire. Then reverse the leads, checking the wires again. Once more, you should get a reading in one direction and none in the other.
Note that the reading obtained from the red rectifier wire will be lower then what is obtained from the other wires.
Any deviation from the "Reading", "No Reading" as above indicates a faulty rectifier. Note that a rectifier will not tolerate reverse polarity. Simply touching the battery with the cables in the reverse order or hooking up a battery charger backwards will blow the diodes in the rectifier assy immediately.
Be sure to let us know what you find.
Dbobjack
Had been working on motor in spare time,as I stated before ohms we're 672 next time i checked they had gone up to 1050, dva 350+ unhooked from pp hooked to pp flashing numbers so fast unable to read.Trying to read dva at orange coil wire same flashing B's no fire on #2 coil is good swapped trigger wires around #2 will fire #1 this tells me trigger is good no wire will fire #2,as I said before I have new pp but wierd readings on stator didn't want to fry it.
Joe Reeves
I gave you the information I knew from experience would be useful to you. It's really all you need.
I do not use a DVA meter. A analog ohm meter is all you need for that simple, easy to understand Magneto Capacitance Discharge ignition system.
Don't overthink it, it'll drive you nuts.
Dbobjack
Thanks everyone for your suggestions,the rec is new and charging battery at idle 13.6 did install new pp engine fires right up with one touch of choke kill wire had .033 voltage but disconnected anyway time for lake test lakes in this 300 mile radius are roughly 30 feet above normal can't get to ramps,,,when it rains it pours,damn the bad luck!!
