454 mpi mag fuel rail
Chiefdave
anybody have info on how to re-install a fuel rail on a 454 mpi mag. Having a heck of a time getting the fuel rail lined up with injectors and seated. There has got to be a trick
Bt Doctur
Patience and lubricant K-Y on the O rings for the injectors . Slow and gentle to seat then and then bolt the rail down. You may need a third hand too
wrench 3
I use silicone grease on the O rings. It's usually easier to put the injectors into the fuel rial first and then put the assembly into the intake manifold. There's a better taper going into the manifold than the rail.
alldodge
It's usually easier to put the injectors into the fuel rial first and then put the assembly into the intake manifold. .
Agree, just did this couple years ago. Use K-Y or such and install in the rail first, watch closly that the O rings don't pinch when going into the rail.
Choose your side, but install all the manifold side O rings in the manifold on one side, and install the other side manifold O rings on the injectors.
Now start the injectors without man O rings into the man and then tilt down the other side
