Fiberglass Mat for Floor
smitty112233
I bought some fiberglass mat on ebay that is, I think, 24 oz mat. Is this to heavy to use for the floor or will it be ok and just take up a lot of resin. If it is too much what is better to use? I can't really find any info on what weight to use.<br /><br />Thanks
crab bait
Re: Fiberglass Mat for Floor
what is the purpose/what are you trying to do with the floor..??
qaztwo
I bought a crazy amount of 24 oz roving on ebay. When I finished the transom and stringers still had around 20 yrds left so I decided to do the floor in 24 also. First time using glass and resin thought the heavy the better. Being roving I did not use as much resin as you are going to use, but for the floor was around a gallon and a half on a 20 foot boat. I will say this, the floor is as tough as nails.
prockvoan
That 24 oz matt will build up around 3/16",you will be using alot of resin,but it will work.Good side of it,the plywood that you use,you could drop down to 1/4".
BillP
I don't think they make 24oz mat. It is probably roven woven. Mat is measured by sq ft so 3oz is actually 27oz if calculated (sq yd)like woven roven is.
Eggkr8
Sorry for the minor hijack. I am also at the point where I need to source the fiberglass for my floor (16" v hull closed bow). I was planning on using 0.5" pressure treated plywood (original was 3/8ths untreated). I just found a good length of 5.5 oz cloth 48" wide. Here are my questions<br />1) is 5.5 oz cloth good for this application<br />2) at the widest my floor is like 52" and I want to cloth the floor to the sides with an additional 8" or so of fiberlgass. Is it ok to have a seam where the finger glass mats butt against each other or do I truly need one continuous pice for some reason<br /><br />again sory for the hijack, but I thought it might be applicable to your questions
BillP
Originally posted by Eggkr8:<br /> Sorry for the minor hijack. I am also at the point where I need to source the fiberglass for my floor (16" v hull closed bow). I was planning on using 0.5" pressure treated plywood (original was 3/8ths untreated). I just found a good length of 5.5 oz cloth 48" wide. Here are my questions<br />1) is 5.5 oz cloth good for this application<br />2) at the widest my floor is like 52" and I want to cloth the floor to the sides with an additional 8" or so of fiberlgass. Is it ok to have a seam where the finger glass mats butt against each other or do I truly need one continuous pice for some reason<br /><br />again sory for the hijack, but I thought it might be applicable to your questions
It is for ding protection and 5 oz will give plenty of protection. Normal glassing practice is to overlap and feather the seams smooth. Glass it first and then come back with a resin fill coat. It fills between the weave and leaves a sanding surface so you don't sand glass off (except at the overlap).
Eggkr8
I know there are debates about resin vs. poly and that resins may not bond well to poly. Is there a way of testing to determine which I have on my hull? I wouldn't want to put in new floors to only have them delaminate from the sidewalls, let along what happens to a delaminated transom!<br /><br /><br />I was originally going to do epoxy and call it done, but then I just compared the prices of poly vs. epoxy!
fishingdan
Epoxy will bond to poly, gelcoat or epoxy (make sure the surface prepared). Poly and gelcoat will not bond to epoxy.
Eggkr8
Hi Dan,<br /><br />Thanks for the input. that still leaves my question of how do I know which my boat is (1964 16' runabout) epoxy or poly? If a boat has gelcoat on it, does that mean that it has to be poly?<br /><br />cheers
Boomyal
Most all boats have been made of polyester resin.
Eggkr8
My mind and my wallet thank you all!
