What did I break
TroyNic
Bottomed my mercruiser 470 out in the water and now am getting a strange noise when going in gear or reverse, it still engages but is a much different sound than prior to incident.
wrench 3
:noidea:Have you done a visual inspection of the drive?
we cant see your drive, so you have to look to see what you broke.
gm280
Post some pictures. They say so much more then words most of the time...
harringtondav
Not sure what to look for, it looks intact, well , bent prop
All of the above. Too little info to provide much help. Spin your prop and keep an eye on the center of the shaft. If it wobbles visibly, it's bent. If its severely bent, it could be the cause "a much different sound".
