rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 920
Hate to ask, as there is alot of tips on here.....and I've done a bunch of stuck head removals.
But this one. RGGGG. I'm about to hack into the adapter and sacrifice it.
I did the "side-drill" method to cut the long bolts. Had to drill through 3 on one side, 1 on the other. The front nuts/bolts, and rear nuts came off fine. Not sure of those stud are stuck yet.
cutting thru the long bolts, I left about 1/2" of the bolt below the Powerhead to be able to get those out once the PH is off. BUT CANNOT BUDGE THAT BAD BOY.
Just the gasket, and whatever corrosion on those 4 "cutt-through" long bolts and if any corrosion on the front/rear studs Is holding it on.
I've used MAP gas on those areas, hanging it completely off the floor from the flywheel. NADA, NOTHING. Tried to tap a razor blade into gap, to start a seperation. NADA. There is really no way to pry or apply needed seperation pressure.
I'm almost ready to hack apart the adapter, to save my good powerhead and continue my project.
Tips anyone...Adapters seem expensive, but so is a week worth of dealing with this one
