Mq 11c 9.5 1965
Crosbyman
anything special about the model… I find little info on it parts wise
They used to shake a lot at idle.-----Factory offered a kit to alleviate that.-----Note-----No " bad design " carbon seal on the crankshaft on them.
boobie
No, It's just plain old and a lot of the parts are probably NLA. I believe it's the 2nd year of the 9.5.
Crosbyman
I am familiar with turtles I have my like new 9.5 9622a
I also repaired a few...never paid more than $60 plus parts (coils/impellers mostly) and sold them….. all are running good
as for nasty carbon seal…for my 5.5 I found one (new) for $10 on Kijiji from a fellow 20 minutes away :)
did not tell him they are asking 47$ and taxes at the BRP dealer
The 64 and 65 model shook a lot at idle.-----Factory offered a kit to alleviate it.----Later models had the vibration dampers installed at factory.------Other than that the 65 models were not much different that the 73 models.-----Last few years did have reed valves relocated.-----And where are you looking for the parts info ????
F_R
Agreed, they shake a lot at idle, and that shaking keeps it from idling well. My dad had one back in "The Day" and was happy with it, but I borrowed it a few times and found the poor idle to be irritating. Guess I should have updated it for him, but I had problems of my own back then. Dang near died, in fact.
Also, I suppose you are already familiar with the smoke inhalation problems common to the 9.5's.
Crosbyman
tried marineengine.com and the mq11 did not show listed in 1965 only Evinrudes come up although I realized they are very similar
the mag plate on these as a funny clicker at the back…..clicks while rotating the mag plate andthe LS needle works with a linkage versus a cabled needle
in any event this one was a freebie 0$$ the cyl head was changed on it why ?? did it overheat ?? I have little history on it it came from an old couple clearing the shed i'll know later this winter if it will be a runner or parts supply
I got 3 motors to work on this winter so I am hoping for lots of snow :)
The cowling cosmetics and paint colour are different on the Evinrude model-----As you should know the parts are all the same between the 2 marketing departments of OMC
Crosbyman
true but i was just wondering since both J&E are generally listed at that **** place :tea::smow:
?----Not everything is perfect and understandable on those parts lists.-----There are omissions and mistakes.-----But if you can not spot or know the mistakes then you will be led astray !!-----You might look to see if the kit was installed on this motor or find one on E-bay.
