charly1954
Thread starter- Joined
- May 19, 2010
- 58
I've searched the net with no luck on its voltage. MK site doesn't have any info on it its too old. From little info I have found I think its a late 1990's model and not sure if it runs on 24 or 12. No where is it labeled 24v or 12v. From what I read even if I found the voltage the foot pedal probably will not work, guess lots of those with the square plug go bad. If can't get it working will mark it up to a small $25 loss.
Whats wrote on the motor
Can't find a model number
serial number is MKFR1018413
motor w/prop says Quiet Turbo Pro Power
Side of the mounting bracket says autopilot
Top of mounting bracket says, Turbo Pro 812 42# thrust
Top of power head says, weedless Wedge Propeller Auto-Pilot
I think the pedal is a Power Drive V1 has square plug.
