I am new to outboard repair and am working on a 1989 15hp 2 stroke Evinrude (E15RCEC). I originally split the case to replace the upper crankshaft bearing because there was a lot of side to side slop on the shaft and oil was leaking past the seal. Once in there I saw ridges near the center of the crankshaft where it rides on the Labyrinth seal and the center bearing seems to have slop in it as well. The lower bearing feels good (See photo) . Is this crankshaft toast or is it acceptable to just replace the bearings??
