G
Guest
Guest
Was out the other day on my Hiliner CC, 98 OceanPro 200 was stompin a groove down river at about 3800 rpm. All of the sudden, the engine started making a intemittent "clunk" sopund, then it resumed running smoothly. it acted as if I hit something, but I know I didn't. aAfter about 30 seconds, It did it again, as if the lower unit was tring to lock up, but it was moving to fast to stop.
I throttled back off plane, and the motor ran smoothly. I got back on plane at 3100 rpm and it ran smothly with no issues. going beyond that, and the "clunk". comes back.
I ran the boat a little longer, staying under 3100, and it ran beautfully with no issue. Got it home, and tried to open the gearcase plugs, no dice, I'm waiting on an impact driver, so I don't jimmie up the slotted screw head.
I'm hoping I can save this gearcase, it may have water in it, but the prop turns very smoothly with no noises or resistance when turnd by hand.
Has anyone had a similar experience?
I had a 1960's Johnson big twin 40 in high school that did this same thing, it eventually locked up the gearcase and rung the driveshaft off in the lower unit. Needless to say, I had to replace the lower unit on that motor.
My O-Pro is not there yet, but I may be looking at an SEI replacement lower (yeah, I've heard good and bad about those, but 2 grand for an OEM is a little rich) if this turns out for the worst.
