Mercruiser 4.3l stalls after restart / rest for 5-10 minutes
Gregdufour
Hi there. I have a 2006 four winns h180 with a Mercruiser 4.3l MCM. I have only just bought it. When I take it out first up in the day it runs beautifully. It runs at 175 degrees. We bring the boat in and turn off the engine for 5-10 minutes while we swap riders. When we take off again at half throttle getting a rider up the engine sits at 3000rpm 25Mph then stalls about 20 seconds after getting on plane. The engine cuts out. Restarts again and then runs fine until we stop at the beach next time with no more stalls. We then stop again for 5 -10 minutes to swap riders and it happens again. This is very regular. If i go slowly after a restart no problems. Only when I give it some. Have just had it serviced and the mechanic cant work it out. Any ideas? Greg
tacx
Check your fuel tank vent. It could be plugged. If its plugged, or partially plugged, your engine will run after it sits a bit, but will die when the air in the tank does not get replaced through the vent when running. At slow speeds the vent may be allowing enough air into the tank, but at higher speed it can't keep up with the fuel draw from the engine. Just a thought.
Gregdufour
Thanks for your responses.
Serial no. is 0W627822.
I read somewhere else that it could be the pistons expanding when the boat is cooling down and shrink when heated. After the restart they don't expand quick enough. Could be the piston rings.Is this possible.
Gregdufour
alldodge
IMO no, heat expands and cold contracts (shrinks). There is also not much time in between stop and restart. Don't see how rings would cause the issue, and if rings were a problem then there would probably be other issues as burning oil
Gregdufour
Thanks. If its a fuel supply issue then why only just after the restart 20 seconds after getting on plane and not have the issue after that.
alldodge
I can continue to make more guesses, but that's it, they are just guesses.
Is the fuel pressure low, does the carb start to flood when shut off, is there a fuel restriction? Other things come to mind
Right now, we are guessing, we need some testing to verify something so we have a starting point. You, your mechanic nor I do not know what is happening. Only your mechanic may have done some testing, I say may because there are good and no so good mechanics.
Gregdufour
Hi there,
Just an update on this issue. Had carb cleaned out and had under the distributor cap checked over (all this after initially having a full service). Still having this issue with stalling. Appears it doesn't happen till after an hour or so of boating. Only happens when the engine has been idling for some time. If it idles for a short time (ie when a wakeboarder falls off then turnaround and get them up again) then no issues. If i idle for a few minutes then stalls 10-15 seconds into giving gas. But doesnt stall after that until i idle for a few minutes again. If i dont idle for a few minutes then theres no problem
Also noticed that when it stalls, if i leave it in gear it cuts the motor out once the boat comes to a standstill. If i put it in neutral once it stalls the engines stays on but wont go again until the boat has come to a halt.
Any thoughts appreciated.
Walt T
It is vapor locking. Go to pure-gas.org and find a station near you that sells non ethanol fuel. That will cure it.
alldodge
It's fuel and need to know if your getting to much or to little, but I'm leaning that there is to much.
Have the motor up to temp as normal and remove the flame arrestor. Look down the carb and see if fuel is dripping
The TKS carb when cold has the enrichment valve open which allows more fuel. When the valve is open you will hear a louder hissing. Once the motor warms up the valve closes
Do you hear any of this hissing going on when warm?
wahlejim
Master Chief Petty Officer
Float may be malfunctioning in the carb. What did they do to clean the carb?
Gregdufour
Thanks. I have been told by my mechanic to go with 91 unleaded fuel. I have been using 98 so that may be the issue. Will give this a go first. Cheers.
alldodge
It is not vapor lock, and going to higher octane fuel only cost you more money
Walt T
Classic vapor lock. no harm in filling up with alcohol free gas. free and easy.
