USA_boater
Thread starter- Joined
- Jul 31, 2018
- 277
2004 Volvo Penta 4.3GL inboard
Hoping to get away with the quick way to winterize this season so I:
- Put Stabil in the tank
- Used Camco tank system with Stabil brand -75 pink stuff and ran almost 5 full gallons though the system on the trailer (pink was running out from the exit for most of the duration all the way until the boat was shut off)
- Sprayed Stabil fogging oil in the carb for 10 seconds when Camco tank was almost empty and used it to stall the motor
I just replaced the circ pump, raw water impeller & thermostat in August and also flushed the block and picked the drains at that same time so I saw no need to open the system now as long as enough antifreeze got into the system to dilute the water to an acceptable level. This boat is stored outside in oklahoma; temp rarely goes below 20*F.
I still plan to change the lower unit fluid but that can be done soon, l I just want to know if there is any consensus based on other member's experiences that what I did will protect the motor for winterization? I had originally planned to do it the longer way but life is busy and I know MANY people just use pink stuff; I paid extra for the better stuff over the cheaper -50F generic brand.
Thanks
Thanks
