1986 140 engine replacement
bigsig
I need to replace my 1986 Mercruiser with am Alpha 1 out drive .I bought new head only to find that both the head and block are cracked... ;(
What years will work for a replacement?
Hemi Roid
Mod Edit - Read our rules.
bigsig
I already have a head for the existing motor. I found out the block was cracked as I was starting to put the new head on. So I am looking for a short block. Mod Edit - See above.
bigsig
understood. I am still interested in what to look for in a replacement short block.
alldodge
Agree Bondo is the guy who will know, but since your replacing the block and head, I would think about finding a newer 3.0 motor. Get one from a rotted out hull and use it. The newer motor may have a different coupler but will not be an issue so long as it comes with the new motor
Ayuh,.... Welcome Aboard,...... I believe it was 1990 that the crankshafts changed, so for swappin' Just the short block, a '89 or older,.....
Post- '90 will require a different flywheel, 'n possibly a different coupler,.....
if you just want a block, stick with the 2-piece RMS blocks from pre 1990
if you want the best 3.0 you can get, get a complete post 1992 motor and drive then you get the A1G2 drive as well.
bigsig
Thanks! I don't want to replace the out drive. I really appreciate the feedback!
alldodge
A newer 3.0 will fit your original drive. Only difference in matting is the flywheel, bell housing and coupler, so if it comes with the motor your good
