1971 johnson 85hp motor won't shutoff ? Help
Oceancube
Like title says I have a 1971 johnson 85hp outboard motor that has electro drive shift that I can start with key but cannot shut off once boat is running ! Any ideas or tips on how to get it to shut off or recommendation to what part to replace ? Thanks all !!
oldboat1
Choke to shut off (hopefully). You might look at the key switch M terminals to see that connected wiring is intact, but you may need to replace the key switch.
[BUT not sure that's the switch you have.]
F_R
Easy. There is a "blocking diode" between the key switch and shift switch. It is either blown or somebody has replaced it with a plain wire. Either way, you can't turn it off once running.
Oceancube
I purchased a new one and installed it . But not sure if it's Installed correctly. I'll take a picture and post it on here . Thanks for the diagram
Oceancube
Anyone have a picture of how it supposed to be wired in the shift box?
Oceancube
Here's how it's currently wired if you can see ! I'll upload more pics
Oceancube
So you can see new doide in but like it just splices into the purple with green stripe wire coming from wires from motor . Is this correct ?
F_R
I love a mystery but this one seems to be unsolved. But don't give up. Before somebody says anything, I'll say the shift switch looks a bit wonky with that white wire instead of blue. And yes, newer models had five wires, two of them white, for neutral start protection. But if it is shifting correctly, let's not worry about that.
Back to the original problem, I don't know what to say. It should work. Let's do a bit of troubleshooting and disconnect the diode from the key switch. Will it turn off now? If everything else is right it should turn off, but the prop won't immediately shift to neutral when you run the starter. That is the purpose of the diode---to provide voltage to the shift switch before the motor is running. We all learned this stuff from OMC, back in "The Day"
If it still won't turn off with the diode disconnected, the wiring must be goofed up somewhere else. The purple wires must be getting voltage from some other source than the key switch. Possibly incorrect connections at the terminal strip on the motor. I suppose it could be the key switch itself, but not very likely. More likely, a bad key switch would result in not running at all. Got a voltmeter?
EDIT: Um, I think I got it. Make sure the "monkey nutz" diode at the motor terminal strip is connected Purple/green to Purple/green, and NOT Purple/green to Purple. There should be only the two purple/green wires under the one screw. Refer to the diagram I posted.
