Pink Stain on Boat Seats
starcentral
oops misread, if its on your seats dont use toilet bowl cleaner.
Try mixing degreaser with some water and scrubbing with brush, then wipe with towel. Try a small area first to see if it works first before doing a large area.
achris
More fish than mountain goat
I have moved this post to a more appropriate forum....
Chris..........
iboats mod team
mr 88
Its a mold that is imbedded into the vinyl. You may make the "stain" less visible with different remedies but it will keep popping back. Sometimes it's the grade of vinyl that speeds along the process of the mold appearing and sometimes it's the environment you boat it. Try Googling How to remove pink mold and you will end up with a ton of answers...
robert graham
Use Q-tips and a variety of stain removing chemicals like Chlorox, peroxide, oxalic acid, etc. on very small areas until you determine which works best. I' ve used an old toothbrush to work chemical into surface. Chlorox plus time plus sunlight is a pretty good combination. After stains are removed apply a good vinyl cleaner/UV protectant to surfaces to help protect from future stains....
alldodge
Admiral uses Mr Clean erasers with different products
DouglasW
This might help:
MOD EDIT - Link removed because it links to the spammer's product report.
mr 88
So this post was just a advertisement by the OP ... Look at his user name and the name of the company that was linked to by the post above this one. Seriously ???
alldodge
Wow, I think your right Mr 88
Buzzed right past me; what do you thing GA_Boater
DouglasW
Wow, I didn't even notice it. Good catch. The sad thing is that I saw the same thing happen on another forum a month ago. I should have remembered that.
GA_Boater
I didn't open the thread cuz the suggestion I was going for was to give the boat to a girl! LOL
Chris moved the thread and I moved the scientist. :D
