shift cable micro switch problems
unclebb
89 merc 4.3 alpha one 186 eclipse, boat, the boat mech. down the road done alot of work to my boat, including a new shift cable, it was dieing going into gear. i told him the shift cable needed adjusted, he called said ready to go. he screwed with the micro switch, said it was sticky, but i had same problems, i removed the switch, both wires were very loose had to be causing a short, i repaired, now it just dies going into reverse,i say it needs adjusted, he says its old and sat 2 years and it needs replaced to the upgraded switch system, which i do like,the mechanics of it have to work better than this old rocker set up, but still , it never did this till he put the new cable on, and i no longer have to push in the safety lever on the throttle to engage it,...any thoughts? let him put on the new micro system for 200$ ? find the info and adjust it myself??
achris
More fish than mountain goat
If the switch itself is not faulty, don't waste money on putting a new one in. Make sure the spring for the lever is doing its job. Adjust the cable, then adjust the switch.
Chris...
Bt Doctur
And if your on land and the switch is operating correctly you need a new lower shift cable and find a better mechanic.
Remove the lower shift cable from the stud
Apply grease to your thumb and index finger
Shift from F thru R
If finger slips, cable is bad, binding, kinked, improperly installed or has corrosion in there someplace
Rick Stephens
I prefer working on the old style roller type like you have. They are easier to adjust. You need the correct manual to adjust the linkage and switch up correctly... well, at least for the switch. The best manual for the linkage is achris's video.
unclebb
copy that guys, thanks again....and yes bt doctur i do need a better mechanic, hes just so close and much cheaper than the marina. i know, you get what you pay for. lol......achris , very nice video, as a shade tree mechanic i would feel comfortable adjusting that style of mech. after watching you
