mercruiser gear oil leaking.
xltier
I have a 1994 crownline bow rider for tubing that has a gen 2 outdrive that is leaking oil in the u joint bellows.i pulled the drive and it pressure test at 15lbs ok. anybody ever seen that before.
Bt Doctur
called a rotating seal leak, can also be from loose input assembly. disassemble, inspect yoke for grooving, install new seal. presure test to 10 psi
harringtondav
Did you see lube coming out around the yoke? That is a single seal that holds vacuum, but releases pressure. So a little lube isn't unusual.
xltier
I went thru 3 monitor bottles full in less than 1/2 tank of gas.
Bt Doctur
I have a good input shaft assembly less bearings from a gen ii on the shelf, PM if interested
harringtondav
I don`t think so
I think you're right. I'm always confused with that seal, especially when replacing. Dislecia. Thinking l put mine in backwards during last winters seal job. My son used a 1/2 " of lube over the weekend. Bet I find it in the drive shaft bellows this winter. Garter spring inside Right?
achris
More fish than mountain goat
Right.
xltier
I just thought pressure testing was a safe bet for no leaks.
stang32
I'M confused, he said he pressure tested it and it held. im dealing with the same issue. the drive was resealed in june but now has a bellows full of oil and a cup full in the drive. pressure test done and it holds at 15psi, 10 psi & 5 psi. rotating ytoke several times each time i check on it with no drop in pressure.
Bt Doctur
I wonder if mercruiser is having the seal problem again I use a National seal that is the oem from years ago
Bt Doctur
National 712250 it is the original seal that was listed as 483323VGO and used in the early drives
