Seafoam vs regular mix has?
Wetwilly62
Ran my boat today on 2 gallons of fuel with 2 cans seafoam cleaner. Ran awesome. 5100 rpm .Once I ran that out hooked motor back up to regular mix fuel. Dropped back to 3900 RPM's.? Anyone know why the difference?
because the tank with the regular mix has an issue?
F_R
Sea Foam loosened a chunk of carbon that lodged into a spark plug??
Wetwilly62
Or the gas in the tank, vent issue or plumbing to the motor issue.
What does this mean?
I've been buying non ethanol 84 octane from the same place. I think it may be fuel.ran twice as long on half the fuel.
Wetwilly62
OK, but did a hunk of carbon get in the new plug? Worth checking
Plugs were clean.. 1 understand these old 1977 55hp are a little higher compression. Maybe higher octane fuel may help , I may be battling some detonation or pre ignition. Issues. Or maybe just bad gas .Just cant get higher octane non ethanol where I am unless I go to race fuel.
GA_Boater
Why not try the small tank with only a 50:1 mix, no Seafoam? See what happens.
I do think you have a problem with the main tank or plumbing.
Wetwilly62
Gonna give that a try. Will update later with results. Thanks
Your not helping by running on 84 octane. Minimum should be 87
icwingman
get some octane booster from an auto parts and try that, but i would drain all old gas out of tank, check all filters and do it again
schematic
200 rpm is not a great difference. Certainly not a dead cylinder from ignition failure, as it would drop atleast 1000 rpm. Even fuel quality could cause this.
