supercab78
Thread starter- Joined
- Sep 6, 2004
- 158
Why won't my resin set up?
I was putting some poly-resin that I thinned with MEK (could not find styrene & on side of can it said it could be used to thin resin, and that it had a slower evaporetion than acitone)The resin that was LEFT OVER IN THE MIXING CONTAINERS did set up. The resin on the wood that soaked in is just a little tacky not hard at all.On the few places where the resin was a little thicker is(about 1/16 of an inch) it is set up a little. It's has been about 40 hours. The temps in the garage have been about 40 to 50 degrees, but it has been very damp out. Can temps and humidity have that big of an effect? I now have a cover over it with a heater and fan blowing to see what happens. If it's not setting up because I didn't use enough hardener what should I try to do? Would it work if I used a spay bottle and misted a hardener on top. Jeff
