Greetings I finished re-building the carb and fuel tank, and started on the electrical. The coils were original and no good, decided to replace coils, points, condenser and plug wires. I found all parts, including solid core plug wires. I removed the magneto plate to route the plug wires and placed it back on, then noticed the word "Top" on the cam. I also have a few other questions:
1) Is there a mark on the plate that should align with the word "top" on the cam?
2) Where do the leads from the kill switch connect? Probably the points, but I want to be sure.
3) I bought a Sierra (Zhangferd?) coil(s), they have one green and one black wire. One goes to ground, the other goes to points, which is which? The black wire is on the top of the coil and I have seen it being used as a ground in videos, but green is a universal color for ground.
4) Will placing/pulling the flywheel result in the correct position the coil clearance? Or do I place/pull, mark the location of the coils and then move them in just a bit?
When I re-built tank, I replaced two "O" rings for the female end of the fuel line. Should the same be done on the connection at the engine?
I'm still having run with this project and have learned quite a bit, thanks for the help!
