Upper shift arm seal
Jamz33
i am having to replace the seal that sits under the shift arm circled in yellow. Does this go in flat side up and spring side down or vice versa?
alldodge
On a lip type seal, the lip always faces toward what your trying to keep out. You don't want water and exhaust gases into the shift arm area, so lip faces down
harringtondav
Check the stickies by Don S at the top of this forum. He shows how to make tools to get your job done.
ps. The screw in that arm can be a bear, and want's to strip it's screwdriver slot. Since you're replacing the seal anyway, get it very hot with a heat gun to soften the Loctite that was (should have been) applied to the threads.
