Tripletcrappie
Thread starter- Joined
- Jul 30, 2018
- 6
I recently purchased a 1991 stratos 274fs with 150 faststrike. No jake plate. My max speed right right is roughly 45 with 21pitxh aluminum prop running around 5700 to 5800 rpms. What prop do you recommend for max speed? Also idle is little rough. Sometimes it will die several times while trying to put into gear. Eventually after several tries it will finally go into gear and run. It runs really good when you have the gas into it. Any tips on helping this. Thanks
