Lower unit
21bravo
Ok so i found this chart here that shows a 93 evinrude 50 interchanges with a 98 evinrude 50 lower unit. Is there anything i should worry about or just bolt it right up? Thanks.
  • [h=2]Lower unit interchange chart[/h] October 20th, 2009, 11:20 PM
    I have seen quite a number of posts asking for this so here goes:
    .....(This chart for direct bolt on with no part changes)............
    Horsepower--------------------------------------Years that interchange
    40/48/50/55/60..... (small diameter housing)..................1976-1988
    40/48/50................................................ .................1989-1992
    40/48/50................................................ .................1993-2005
    70/75............................(20 inch shaft)......................1978-late 1981
    60/65/70/75................................................ .............1982-1988
    50/60/70................................................ ..................1989-2001
    85-140.............(crossflow 13 spline prop shaft).............1978-1991
    88-140.............(crossflow 13 spline prop shaft)..............1992-1998
    120-140 Looper V-4... (15 spline prop shaft)...................1985-1991
    75-115 60 degree........(bat wing unit 13 spline)...............1995-2006
    150-235 & 2.6.................(crossflow V-6)......................1979-1991
    185-225.........................(Looper V-6).........................1986-1991
    185-
21bravo
It will bolt right on.
Thanks for replying. That sale fell thru. I have found a 92 johnson 70hp. This chart shows it will change with a 98 50hp evinrude. Is this direct bolt or will i need to do something else? Thanks for your help.
21bravo
Clarify your question with 2 or 3 cylinder motors or model #.
Ok my motor is a 98 model # E50TSLECC
his 92 model # is J70TLEND
is this enough info?
Not sure but looks like the 70 is 3 cylinders loling at a parts diagram online by model number. The 50 is 2 cylinder. If needed ill ask about how many cylinders it is. Thanks again
flyingscott
According to your chart no it will not interchange. 3 cylinder lowers interchange with 3 cylinder motors. 2 cylinder lowers interchange with 2 cylinder motors.
The 98 model 50 HP motor is a 2 cylinder and a 3 cylinder lower will not fit.
