Ignition switch is getting no power
can someone help me please? My 2001 chap. SSI 220 has no power to the ignition switch, the battery are all good, and we have had the ignition key it’s self tested and that was good. When I put the Volt meter on the wires that run to the ignition switch they have now volts does anyone know where a fuse may be or loose connection that would cause no power to ignition switch? Thank you
Big 90 amp fuse at the starter or 50 amp circuit breaker depending on year
alldodge
Follow the Red/Purple wire back and look for an in line fuse, it should be 20 amps
alldodge
I have searched everywhere under the dash and behind it and can find no fuse box
Not looking for a fuse BOX, its an inline single fuse. If its not behind the panel, it is in a fuse or breaker panel/box in another location. Every boat has one, its just trying to find it, and most is an inline fuse
