1967 Johnson 80hp Electromatic Shifting problem
KD2ITW
searching many forums I discovered a few diagnostic tests.
with shift lever in forward I see 12v at the green wire connector in the rear of the engine.
with shift lever in reverse I see 12v at the blue wire connector in the rear of the engine.
i May have the colors reversed??
i see 4 ohms on each wire going to the gear case.
in neutral, the engine spins freely when trying to start it.
with the shift lever in either forward or reverse, the engine cranks very hard and the prop turns clockwise only.
I'm leaning towards an issue in the gear case at this point.
any clues how to proceed would help.
my 77 year old neighbor with no computer thanks you in advance.
jimmbo
So what is the reason you are troubleshooting this unit? Not shifting into one of the gears?
4 ohms sounds a bit low.
Did you get an ohm reading of the coils in series?
You say the engine cranks slower when in gear? Normally I would say that should make no difference, but since the shift coil is drawing power in this case, maybe there are voltage issues.
You say the prop rotates clockwise regardless of which direction is chosen?
F_R
Yeah, I just looked it up Resistance is supposed to be 8 Ohms. I'll bet the green and blue wires are shorted together somewhere. That is making it go in both gears at the same time.
KD2ITW
Neutral and forward only, no reverse gear.
ohms were read one wire at a time to ground.
yes the prop only rotates clockwise.
KD2ITW
Bingo! While I was away from him for 2 hours, he started the engine and put it in gear, it stalled immediately.
he just couldn’t wait for your responses.
KD2ITW
Let’s hope he didn’t ruin the the whole bottom end by by starting the engine then engaging the gears.
we lowered the unit this afternoon.
I will go over and check the wiring and correctly fix his wire repair in the morning.
i can check for correct 8 ohms before and after the wire repair.
Thank you so much for taking the time to reply and put me in the right direction.
best regards.
jimmbo
If both coils were energizing, and both forward and reverse springs were engaging, the engine would stall and there would only be neutral and engine not running. You said the engine stayed running and the prop turned in forward, but didn't turn in reverse.
Or is it now stalling in both forward and reverse?
I think the case is going to have to come apart
KD2ITW
best regards.
KD2ITW
Ok,we are good to go.
First thing I checked after removing the poor patch was to check for 8 ohms to individual coils. 8 on one and 7.8 on the other.
I rewired the patch and again check for 8 ohms on both wires, same results as above.
i took 12v and ground to the lower unit while it was still on the bench.
I have neutral with no voltage applied. 12v to one wire correctly gave me forward. 12v to the other correctly gave me reverse.
we are out of the woods.
Thanks again for all the valuable information!!
jimmbo
When you applied voltage to a wire and said one gave one forward and the other reverse, how were you verifying that? Power to the forward coil would let you rotate the prop shaft clockwise, but rotating it counterclockwise, you would feel some drag then it would hit a stop. Energizing the reverse coil, will let you rotate the prop shaft counterclockwise, but when rotated clockwise it would lock up.
KD2ITW
while the lower unit was removed to effect the repair to the wires, we set it on a table. Rotating the drive shaft clockwise with no voltage applied to either wire resulted in no prop movement.
Appling +12v to one wire and rotating the drive shaft clockwise resulted in correct prop rotation for forward propulsion.
Appling +12v to the other wire and rotating the drive shaft clockwise resulted in correct prop rotation for reverse propulsion.
I’m satisfied that it is functioning correctly.
jimmbo
Ok, you rotated the driveshaft, and got the expected results. Others will spin the prop shaft and get confused by the results. Hopefully you lucked out and you’re good to go
F_R
When both clutches lock up at the same time while running at a significant speed, it often twists the drive shaft in two. Obviously, that hasn't happened here. So put it back together and go boating.
Those clutches are tougher than most people give them credit for.
jimmbo
After seeing how some people would repeatedly shift from Forward, directly to Reverse, bypassing Neutral, and then back while running at speeds over 1000 rpm, I figured the units were stronger than they looked. Maybe the 1.15:1[23:20] gear ratio had something to do with it,(little torque multiplication compared to later 2:1 and higher ratios in non electric cases)
