dlogvine
Master Chief Petty Officer
Thread starter- Joined
- May 4, 2015
- 839
Another problem, this is such a pain in the neck. After all bellows were replaced, i checked the bearing alignment with the alignment tool, looked centered and was spinning effortlessly. Tried to install the outdrive but this sucker first went in to the position where the bolts were aligned right below the edge of he outdrive but was not able to slide it any further despite pulling he outdrive up and down and rattling it numerous times. I had exactly the same problem last time I removed his same outdrive, it refused to slide in and took me several hours of cursing and jerking it back and force, up and down until the stubborn sob went in. But this time stupid me, i decided to take a look inside and double check the bearing, u-joint bellow ring and i pulled the outdrive completely out. Of course all the above mentioned parts were sitting riht at their places, but Now this sucker refuses to go any further than the position where the bolts are almost touching the outdrive but does not slide in any more. Any advice as to what can i do short of spending another several hous curing and moving it up and down in a hope that it will change its damn mind and slides in. Thank you.
