1981 Johnson 25hp prop help
Dopemodz
Yes i have a 1981 johnson 25hp 2c short shaft. It has the exhaust port above prop. It has the stock prop that is a 9.2x14 13spline non thru. Its alittle beat up and im trying to find another 9.2x14 or a size i could use with my 14ft semi vhull aluminium boat. Ive found 9.25x12 but dont know if 12pitch would be enough for my boat. It does 20 3/4 throttle and 25 full throttle with the wore out prop. Would like to go alittle faster or the same.
Dopemodz
Need prop info
I have a 1981 johnson 25hp with a 9.2x14 13sp non thru exhaust prop and im in need of a new one but dont know if i could use a 9.25x12 and it be near the same. The prop i have is stock from 1981 and its wore out and chipped. Its on a 14ft semi vhull aluminium boat.
Sea Rider
With a 12 pitch prop will achieve more wot rpm than with a 14 pitch, how much, can't possibly tell without a induction tach installed. If like boating heavily loaded combo will respond much faster than with a 14 pitch prop.
Happy Boating
jimmbo
I have never heard of a 14" pitch prop for that engine. The engine was shipped with an 11" from the factory, the range offered by OMC for that engine stopped at 12"
Dopemodz
We had a 79 25hp on a 14 ft hull and we used the 11"
Thats crazy . Ill look again but most likely get a 12 pitch
jasper60103
A general rule is the heavier the load, the lower the pitch, and vice-versa . Also, you want to insure you're operating in the proper RPM range (4500-5500) at WOT. You should verify with a tach, not speed. There is a prop sub forum that can give better guidance than me though.
Dopemodz
Okay so if there is a non thru exhaust prop on the outboard is there anyway to use a thru exhaust even though the motor wont use it. Just hard trying to find a non thru exhaust 9.2x14 prop for my 81 johnson. It has the 13 spline
Sea Rider
Nope, both lower legs are quite different, can't interchange props between them. That's the issue of boating with Jurassic Outboards. Send current damaged prop to a prop shop and have it rebuilt to new condition.
Wot max revs as loaded is all, speed achieved is secondary...
Happy Boating
hardwater fisherman
Looking at the BRP website the 12 pitch is the highest pitch. I have a couple 10 pitch props for your motor but I have not seen a 14 pitch, I can not find a new 14 pitch for my 1976 40hp evinrude either. I am not saying that they dont exist but might be hard to find.
F_R
Yeah, my ears perked up when I heard 14". That don't seem right.
Dopemodz
I will take a picture and saw yall tomorrow . it says 9.2x14. But im thinking get a new 12pitch and rebuild the 14pitch
