budget boater
Thread starter- Joined
- Jun 22, 2018
- 4
Ok im sure this has been gone over a time or two but I have been looking for months now and even with going in depth on forums everywhere I found I still have not came to the answer for my problems. anyways I have a 1989 arriva with a force 120. ok time for the bad.. the outboard had no markings as far as year or id plate. what I do know is that the electronics have all been replaced with a setup from a 1991 force 120. now the real issue at hand is top end boggs at half throttle. all I get is a deep throaty sound and nothing more. things I have went over include the following compression is sitting at 98 to 95 on all 4 stator ohms check out to be good it has aftermarket cdi stator part 174-8778k1 along with a new rectifier from cd1 part 194-5279. I don't have the adapter for the dva test. carbs have been gone threw a 3 times as well as new plugs.timing is spot on. two weeks ago I had it out on the lake and it was running with no top end power what so ever after about an hour of messing with it on the water the rpms dropped to zero and the boat took off like a rocket wide open up on plane and ran great. it would idle take throttle and jump right up to speed like it should. now we went to the dock let it sit for an hour when we returned it was back to the old ways tach working and way underpowered. I thought it was rectifier so I canged it and nothing infact therpm gauge doesn't work at all now. please help me guys my family is wanting to go play on the water and the kids are driving us nuts. thanks
