Need help on a friend's boat - Tach/Speedo Not Working
cloudd21
Got a 99 crownline boat the tach gauge does work but the hours show up or miles and speedometer doesn't work either the back light works it has 5.7 gsi engine in it
GA_Boater
In summary;
  • Tach works
  • Instrument backlighting works
  • Hourmeter in tach works
  • Speedo doesn't work
Correct?
tach has 3 wires to the gauge and 2 to the light
the light is a blue wire (light power) and black wire (ground)
the tach is a grey wire for signal (runs to negative terminal on coil), purple wire for power (ignition power from key switch) and black wire (ground)
so if the tach is not working (still confused on this), then either there is no power on the purple wire, or a bad connection on the black wire or there is no signal on the grey wire or the tach is dead
cloudd21
The speedometer doesn't work either so do I need to test which wires how can I test them
kawakx125
good lord i'm confused. best i can figure is that neither gauge works, which would lead me to believe there is a power issue somewhere else possibly
cloudd21
I have power to purple wire when key is on is there a way I can test the grey wire for the tach
Maclin
The speedometer probably runs off a pitot tube that runs up from a fitting on the transom.
cloudd21
I cleared the line with water and made sure the tube on the boat was clear of debris and dirt so know how can I test the speedometer gauge
use a multi-meter, set it to frequency, read the frequency at the coil with the motor running, then read it at the gauge....should read the same
blow in the tube, gauge should move
