Captain Jeff
Thread starter- Joined
- Jun 15, 2005
- 161
1999 Johnson 115 60 deg V4 J115PXEEM
Hi, I have never really been able to get a good idle on this engine. Last season I rebuilt all 4 carbs including new bowls and floats. Rebuilt the vapor separator and primer solenoid. Installed a new water separating fuel filter and primer bulb. Also a brand new VRO unit. I'm pretty confident I rebuilt the carbs well. This was probably the third time I rebuilt them and I am very careful during the process. Also cleaned the optical sensor and timing wheel and I checked spark on all 4 cylinders and had a good blue spark jumping the gap on the tester. I also checked compression and had around 115-120 on each cylinder. I also cleaned the oil tank and replaced the oil line and bulb last season. New spark plugs too.
I just did a link and sync today with the OMC ignition analyzer and there was a noticeable improvement in idle quality. It idles smoother but still not perfect. The main issue I have is that it stalls and seems to idle high (800-900 RPMs on earmuffs). It may seem to idle fine and then suddenly stall. It doesn't gradually die out as if it had a fuel restriction and it will restart instantly with a turn of the key.
Here is an example of what it does, you'll notice the idle starts out ok and then gets a little rough and stalls at the end. The engine is already warm and out of fast start in this video.
https://www.youtube.com/watch?v=qTfyr9tSQc0
Here is one time when it stalled and actually had a flame come out of the prop.
https://www.youtube.com/watch?v=8kAdhjxv5q4
The next thing I was going to try would be to adjust the idle screws on the throttle bodies. I thought it could be a lean sneeze but I'm not sure. I noticed the hex key idle screws seem to have a little play in them so maybe they vibrated lose. Does anyone know how many turns to adjust them? My Clymers manual doesn't have the setting. Any ideas of what else I can try? Thank you!
