Lower wont fully seat after doing impeller
jturbo86
I removed the lower (in full forward) and now when I try to put it back together, there is a one inch gap. Ive rotate the prop for an hour and its just not doing it, very well greased as well.
Also, another concern I have is that the drive does not like to say in the forward position, it will gladly stay in reverse as I rotate the prop to get the shaft to turn, but if I put it in forward (right handed prop, clockwise for forward).
Bare with me here, im extremely mechanically inclined but this is my first time doing an impeller. I wouldn't be asking if I wasnt completely at a loss. Thanks for any help you can offer.
Bertram 20' merc 470/bravo gen 1
jturbo86
Ok so it was the splines, but still confused as to why it keeps going into reverse.... I locked the prop with a ratchet strap prior to install to hold it in F and now it seems like its back in R after installation?
Bt Doctur
the propeller turns to the right so to keep it locked you turn it to the left, this if fwd.
to install a lower unit you are actually turning the prop backwards(to the left) to turn the driveshaft splines to line up while in fwd gear.
jturbo86
Ahhhhh this makes sense now, thank you. It's re-installed but after taking a long rest... and drinking a few beers I installed everything and forgot to zinc bolt :( back off it comes tomorrow. But now I know...... thanks again for the response
nola mike
I've done that before. Doubt we're the first 2.
