Johnson vs evinrude 15hp
Patbarb123
Hi everyone
i have two 15hp outoboard motor
- evinrude 1992
- Johnson 1994
they both work great but i need to sell one but dont know wich one to choose!
can you help me please
thanks
Patbarb123
My concern is that they both work great but they are two différent motor
im wiling to keep the one that is suppose to have less problem thats why im askking your help
maybe some people had problem with the 1992 Year and less and after 94 problem have been solve
thanks!
merkdawg0084
Definitely keep the one that is easier to work on... check to see where thermostat is on both of those. Top is best. They both might be on top., check lower unit oil, check for leaks.
oldboat1
Ignition module on the '92 is under the flywheel, '94 module is on the block. Under the flywheel may cause earlier failure due to heat build up.
thatone123
Banned
Say what? Johnson and Evinrude are the same...is there any real difference? The difference to me is what is better the early sloped cowling or the later rounded cowling with plastic top Mexico carb? I use both on a regular basis and am known as kind of a guru on these. The later mid 90's seem more heavy but the stats say the bacis non-electric short shafts are the same. What ever one has the lowest use and low time seems to be about right. Fantastic outboards, wish they still made em! I have had a couple overheat and no problems, not even a head gasket change. Syn oil is part of the reason I believe.
flyingscott
Keep the 94 motor. The 94 is a 15 cid block as opposed to the 92s 13 cid. The 94 will be a more powerful motor and are generally better idling motors. If you look up the weights the 94 will actually be lighter than the 92 model. The differences are more than the hood between those motors. Both motors used the plastic top carb.
achris
More fish than mountain goat
One problem on all the small 2 cyl OMCs is the grommet at the top of the water tube... Over time it closes up... Easy fix, but can catch you out if you're not aware of it.
Here's picture.... (#19)
thatone123
Banned
Anyone want a real kick get a mid 80's slope cowling 15. These (some - not all) get top end power at 7000 rpm. I believe these were stock racing motors made for the upper mid-west limited race category hydroplane circuit. I have come across a number of them. They are usually cheap!
The 15A was intended for racing.------Stream lined / pointy lower unit.-----No through the hub exhaust.---No gear shift.
flyingscott
The 7000 rpm limit was put on stock production motors nothing special about them.
thatone123
Banned
Then why was the limit 6000 on most of the long history of this outboard? Just wondering?
