Identifying this Evinrude's year
WncMoss
Hi everyone and thanks for having me! I just purchased a 50's Evinrude and i'm trying to find the year as well as the mixture ratio. The gentleman i purchased it from has had it hanging in his garage for 30 years and told me it came from a museum. It still has the leather pull cord! I haven't tried to start it yet and if anyone has tips for me on top of the mixture and year they will be greatly appreciated!! Serial # 7514-04010
a 2 second google search of the serial number gives you 1954 7.5hp
before you even think of starting the wall-art motor it would need the following:
impeller service, coils most likely cracked, points will need to be replaced, fuel system will need to be rebuilt, lower crank seal will most likely need to be replaced
fuel/oil ratio is 24:1
jimmbo
It looks like a 1954 7.5 hp.
Fuel mix would be 1/2 pint of oil per gallon of gas(16:1) DO NOT use 24:1 or leaner, no matter what the Oil Manufacturer says, as this engine has bushings, not anti-friction bearings and the oil is needed to prevent metal to metal contact.
I doubt you would have spark as the coils and condensers are probably well past their best before date
The water pump impeller is too old to even try to use it
There is a link to reviving a comatose outboard
https://forums.iboats.com/forum/engi...rd-by-boatbuoy
Owners manual
http://162.144.28.33/lib/evinrude/ma...eetwin.html#/0
WncMoss
Thank you for the information!
Owners manual
WncMoss
Thanks for the info Scott!
jimmbo
Ignore the lubricant recommendation to use SAE 30, use a TCW-3 oil@16:1
good point on the TCW-3.
not saying that you shouldnt run this old outboard, however the cost of the components to get it running reliably is more than an early 80's vintage 30hp
