- Jul 23, 2011
- 53,280
to all newbies. dont take this as being negative, however we see this daily
We are here to help....however please help us help you
we know you bought a boat without advice and you come here and yell help. slow down and provide details
start with a search. your topic has been covered multiple times. there has been a similar issue with a resolution in the past 4 weeks..... use the search function.
we will give you advice, we will give you guidance, we will push you to do your own research and trouble shooting and to look for the answers yourself. we will not spoon feed you, you are not toddlers.
only one post will suffice, only one is needed. more than one on the same topic will be flagged. you are not helping your cause by posting multiple times
this is not face tube. dont PM us, use the forums
please say more than help.... we need to know what you are working on, what the problem is and most importantly use punctuation.
please when you buy a new to you boat. first thing to do is all the maintenance on the boat, motor and trailer. dont even think of asking for help until you have done that. that includes impellers, fuel system maintenance, engine oil changes, gear oil changes, plug and wire changes, battery testing, battery cable connection cleaning, testing the alternator and starter, trailer bearing and seal service, buffing and waxing your boat, cleaning your boat and applying all the protectants applicable to your boat. this is the stuff you do between the time you pay for the new to you boat and you splash the new to you boat. dont get so prematurely excited and simply drop in the water and hope for the best.
when you say I have a 3.0 or 5.7, keep in mind over the past 50 years there have been many dozens of varieties of your exact motor. include year, type of induction, and serial number. and yes, there have been more than 15 incarnations of the 3.0 over the past 50 years
if you have an over heat and did not start with a new impeller.....start there. if you did not back flush the missing pieces, do so.
if you boat a boat without a title, good luck most of us would have warned you prior
if your boat is bigger than your car, get a truck
boating is expensive, one of the most expensive hobbies in the world, if you cant afford the hobby, take up racing (its actually cheaper)
Thanks in advance......Scott
