Stripping Paint Question
18rabbit
Re: Stripping Paint Question
Ralph – you are correct, a quality heat gun definitely can char wood if held in one place too long. When used correctly (not hard to do) you fan the heat back and forth until the paint loosens, just starts to blister but before the paint chars. The paint scrapes off really easy, like scooping up butter. The wood is warmed but not hot. That’s why I mentioned about working ahead of where you are scraping ... with one hand prepping/heating the next area to be scraped, while the other hand is scraping off the paint that is already loosened. It does not harm the wood and is very quick and clean. There is more concern in accidentally coming in contact with the end of the heat gun ... done that, too ... ouch!!!<br /><br />I like the idea of using plastic. I question the need to let paint remover sit overnight unless it is cold outside, but then I wouldn’t bother with chemical strippers if its not warm. And you are right, stripped paint goobers do turn back into hardened paint when the stripper evaporates. If they sit overnight they can even cut or poke holes in your skin.
jsfinn
The reason I want to try the heat gun first is because half of the paint is peeling off anyways. It doesn't seem like it'll take that much to get it to come off - it just needs a little help. It seems like if I put a stripper on, it'll not only be hard to coat around all the large chunks of peeling paint, but also I think I'd be pushing the peeled paint back on giving it a chance to rebond with the wood.<br /><br />In any case, I already have a heat gun and Lowes isn't that far away to run out and get stripper if the heat gun doesn't do what I want it to.<br /><br />On a side note, I've called every hardware store, paint store, and lumber store in the area. When I ask them if they carry "Bronze Wool", none of them know what I'm talking about. It's easy to find on the internet though. If I end up needing something to scrub with, I think I'll pick up a couple of those plastic 3M scouring pads. They seem like they would work well - maybe not as flexable as wool, but I think I'll be able to work with it.<br /><br />I can't wait till Friday. I'm taking the day off work so I can MY work done! :)
18rabbit
Jsfinn - I bought a big bag of 3M kitchen scouring pads at Costco, yellow sponge with green scrubber side. Use them with Jasco stripper all the time, mostly on metal to remove primer. Just a reminder, if you use a nylon brush (I use a tooth brush in tight areas) wear eye protection. That stripper will splatter and you do not want it anywhere near your peepers.
Ralph 123
Norton (The sandpaper makers) also make synthetic "steel Wool" pads in the various 0 - 00- 000 grades. Very similar to the Scotch brite pads Rabbit is talking about. You can get it at any Home Depot. They keep it near the sandpaper and paints.
jsfinn
Thanks.<br /><br />I stopped by Home Depot last night on my way home from work and picked up a couple of those Norton abrasive pads, a new heavy duty ext. cord, and a couple of scrappers.<br /><br />I'll put pictures up tonight or tomorrow of a stripped boat! (I hope!)<br /><br />I've been thinking - at first, I was going to leave the paint that isn't peeling alone. Now I'm thinking I'll take it off.. I still am not sure - I guess I'll see how easy it comes off and make a decision from there.
petrolhead
It's hard to tell from the photos, but that timber looks pretty sound under the paint, is it as good as it looks?
BillP
Hey, you got a lot done! Most of it looks ready to sand. That was done with stripper, right?<br /><br />I abandoned removal by heat because it took longer than stripper and was more tedious.
jsfinn
It's a little rainy today or else I'd be out there now with the sander.<br /><br />I can't find anything that's soft so I think I'm really lucky - no major repairs! WOOHOO!!!<br /><br />I started with the heat gun, after I got about a square foot done in an hour, I ran out to the hardware store for 3 gallons of stripper. I ended up using about a gallon and a half of "Kleen Strip" spray on stripper. If I was doing this again, I wouldn't get the spray on kind for doing such a large project. The stripper is thick and pulling the trigger on the spray bottle all day really messed up my wrist. Oh, and man does that stuff hurt when it gets on your skin!<br /><br />I'm going to put some CPES on the transom just to put my mind at ease, repair the top where I took off the cabin roof sand the bottom, sand the inside (not down to wood..just enough to clean/prep it for paint)and see what happens from there.
18rabbit
Originally posted by 18rabbit:<br /><br /> ... Buy a gal, pour into a small glass jar, use cheap, 1-½ inch, throw away brushes.<br /><br />... gloves , and safety glasses ...<br />
Hey! Just wait until you get a little dab of that stuff in your arm pit. You'll be doing a war dance. :D
jsfinn
Haha - I used big heavy duty gloves, safety glasses, and a respirator...that stuff still splashes though! I used a small platic container and a cheap brush for a little while... it ate my brush!<br /><br />Hey rabbit, how'd you get it in your arm pit? You're supposed to put it on the boat! :)
18rabbit
I don’t know how it happened. :confused: Got it under my t-shirt! Within minutes I was going thru the appropriate 5 stages of death … denial, anger, bargaining, acceptance, war dance. :D
jsfinn
Haha - glad you survived!<br /><br />I'm the idiot that was wearing flip flops. I had to run over to the hose every 15 mins to wash off my feet!
armillary
Hi Josh. As you know by now, it wasn't a free boat. You're paying for it with lots of sweat and occasional chemical burns. But it's going to be beautiful when it's done. Keep those pictures coming! You're doing it justice. <br /><br />I'm rootin' for ya,<br />Mike
